Starting from scratch a few questions
gforceinteg
Post by gforceinteg »
I was trying to use a s200 converted .bin but am having to much trouble.
I have 97 gsr with p28 ecu. Should I use the usdm p72 base to start or the p28?
also using 750cc saturated, how well does the s300 convert from injector size?
Also, anyone know what wideband comes in the rsx and is can use it with the s300?
What base map you start with will depend on what engine you have. The injectors size adjustment will get you pretty close, but you will need to fine tune as all injectors have different characteristics. The RSX o2 sensor cannot be used as there is no controller for it. The PLX wideband is highly recommended.
