auto ecu with manual gearbox
assix
Post by assix »
Hi guys...
i've already installed a D15B (vtec sohc) into my car. that engine came with an auto trans but i changed with my old manual trans. so now the status is, ecu - auto but gearbox - manual. its really hard to get the manual D15B vtec sohc here! my question is:
- is it harmfull to my engine/ecu/performance or related if i continued to use this ecu?
- any suggestions on how to mod that ecu to make it compatible with da engine?
thanks a lot...
what ecu are you using?
assix
Post by assix »
Spunkster wrote:what ecu are you using?
PO8 i think... for Civic EG8 (JDM)
You can use the s100, s200 or s300 on that ecu and properly tuned it will run great.
assix
Post by assix »
Spunkster wrote:You can use the s100, s200 or s300 on that ecu and properly tuned it will run great.
Thanks a lot, Spunkster.
I must make a correction...the s300 will not fit in that ecu, bu tthe others will. Included in the installation manual are instructions on how to convert the ecu to manual.
