This thing has some Major bugs
D@nny
Post by D@nny »
ggfjhtr
gforceinteg
Post by gforceinteg »
Huh, I havent been able to hit the dyno yet because I dont have an o2 yet to make the safe drive an hour away. I have been having the same problem with changing between key turns. I thought it was my crappy laptop.
Are you using windows xp based laptop? I dont this is why im asking.
QUICKSILVER RACING
Check your basemap
Post by QUICKSILVER RACING »
I'm using 1600cc injectors and no problem.
Water tempcompensation is working fine in my car.
My laptop gives me datalogging problems though.
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
D@nny
Post by D@nny »
im runnign xp on a brand new laptop thats maybe 3 weeks old and I had a reputable tuner tune the car witht he same probelms. I got the unit preordered so maybe there are problems with the first batch??
I really would like to know whats going on as I sent the ecu to cali to be chipped and didnt cut any corners on the setup only to have the car run like crap cold and have the map change by itself....
Can you post the original s200 ROM, and the s300 calibration?
D@nny
Post by D@nny »
I have to speak with the tuner before I post his maps ... are any of these problems being fixed?
You can email the ROM/calibration to support@hondata.com
There is a problem with fuel overrun cutoff and non-stock MAP sensors, being fixed now. This only affects idle.
Without additional information it is hard to tell what might cause the other problems. Which parts of the map (calibration?) change when you save/reload?
Jordo
Post by Jordo »
am i going to have problems, once i convert my 1000cc injector map into it?
i dont want to run lean all of a sudden when i do, my initial pulls.. to start tuning top end.
s300
Shmaa
Post by Shmaa »
I'm having problems with mine too using 750cc injectors, ECT doesn't work, Idle AFR can range from 10.8-15.6 with the same fuel settings. wont idle smooth no matter what at 14.7 afr
Try downloading the latest software from http://www.hondata.net/forum/viewtopic.php?t=3832
Silverbeast
Post by Silverbeast »
The link above will DEFINATLEY fix the idling problems.
D@nny
Post by D@nny »
yes the cold start is much better ....it did richen up the part throttle map when I switched over but that was a quick fix. now jsut get the lamda tracing working and itll be great
