jrsc b16 trouble
slamed91si
jrsc b16 trouble
Post by slamed91si »
i have a 99 si with a jrsc dc heder dc catback hollowed out cat aem cold air and as far as i know the rest is all stock my check engine light has ben on since i bought the car in late summer of 02 the codes are reading map, tps, both o2, intake air temp what is causing this to happen the car also idels really rough and bogs somtimes until wot any little bit of info you have could help thanks
99 civic si
jrsc 6psi
dc header
dc catback
aem cold air
AndyE
Post by AndyE »
This web forum is for discussion of Hondata systems. Please take general questions to other forums like Honda-tech.
-Andy
'99 EBP Si
S200 w/everything|12psi JRSC|Heatshield
AEM CAI|Kamikaze headers
Custom (quiet) 2.5" exhaust
Quaife LSD|JUN 9lb flywheel|ACT XTSS clutch
Eibach Pro-Kit/KYB AGX
Full polyurethane bushings/mounts
OZ 16x7 Superleggera + Sumi HTR Z II
JRSC
I think you'll need to fix those codes before you have any hope of the car running correctly (to say the least)... probably ECU wires missing or broken when installing the JRSC electronics.
