Part Throttle is too rich A/F = 9.9-10.2
alblude
Post by alblude »
When I had it tuned at DynoSpotRacing at full throttle the mixture was REAL lean so we brought that down in 4 runs to acceptable levels. But it seems that part throttle is rich as hell at 9.9 - 10.2. I don't have the .bin files, I guess I'll ask for them, but is there something I can do in the mean while?
temporary fix would be to try and turn down the fuel pressure, but then it will lean out at full throttle.
You need to take it back to the tuner and have some part throttle tuning done.
alblude
Post by alblude »
Spunkster wrote:temporary fix would be to try and turn down the fuel pressure, but then it will lean out at full throttle.
I guess I neglected to mention I'm not using a Wideband. I'm just getting this from my O2 sensor. I called my tuner today and he said that is not accurate. Could the accuracy be that bad at part throttle?
Prelude '96 H22A1 | I/H/E | AEM Pullies | Type-S Cams | Hondata S300 | JRSC
Impossible to say without a wideband reading.
turbosi92
Post by turbosi92 »
Yes, without a wideband tuning won't accurately happen. Case closed.
EGHATCH
Post by EGHATCH »
its almost impossible to run 9s and 10s at part throttle especially at idle. most likely engine will stall and you smoke will be everywhere. go back to your tuner :)
you wont learn until you actually do it.
alblude
Post by alblude »
well a couple of things I guess. Most importantly it wasn't a wideband, second, that reading was from PalmLog 1.0.4. The reading from HondaLogger was anywhere between 8.9 and 12. so clearly they're whacked and definitely need to be disregarded. On that note, I'm wondering what the accuracy of Palm log will be when I DO install the wideband.
