H22A base map setup and other engines for that matter
hybridynamics
Post by hybridynamics »
i never had a problem setting up a base map to at least start the car with the old S200 software, so why am i having such a problem setting up base maps to start the car with S300?
for instance, we have a stock H22a motor, custom turbo kit (nothing crazy), precision 1000cc injectors, stock map sensor, S300 system on a P28 ecu w/ IAB circuits added.
i open up the stock H22a map, change the new injector size to 1000cc, and the car won't even start. it won't even begin to hold an idle until i change the new injector size back down to around 300cc.
is there something i am missing? i miss the old setup of just using an injector multiplier...
Make sure you are using the latest beta software located at http://www.hondata.net/forum/viewtopic.php?t=3832
