matt I need your help asap.
bossman032
Post by bossman032 »
Hey Matt,
My car had been running perfect till on day it fucken stopped working. I thought it was the wiring, I checked over the wiring many, many times. I even called you to get the Kpro tested, you said it might be the wiring. I checked and checked never thinking the kpro might be bad.
till today I find out that the kpro one of the pins got burned.
Please advise, my car has been running ever since I got the kpro like about nearly two years with no problems. Till a few weeks ago.
I don't know how it got burnt. I certainly know I didn't do anything because it just stopped working on its own.
so Matt please let me know can I get it sent in and fixed.
http://pg.photos.yahoo.com/ph/bossman03 ... pg&.src=ph
link to my car.
Pin Location E3 Logic Ground "Ground for ECM Control Circuit" Less than 1.0 V at all times
Please send the ECU to us for testing. Fill out the problem report located at http://www.hondata.com/downloads/K_Problem_Report.doc
Make sure to include you contact details and return shipping info.
It sounds like you may have a problem with the grounds or the way the main relay is wired up. It is possible this has damaged the ecu.
bossman032
thanks for the speedy reply.
I have no clue what caused the problem. I have been using the ECU for 1 years plus, now maybe longer. 8-2-04 is when I got it done.
I will express mail it to you guys can u guys express mail it back?? I spend about 2 weeks trouble shooting the wiring!!! Everything was getting power and thing but no spark.
let me know..
ronald
bossman032
ecu has been sent.
please get it fixed asap.
ronald
