blue box messedup.
highperboi
blue box messedup.
Post by highperboi »
my blue box is messed up one of the pins in the 4 connecter thing broke and i tried to fix it and i got it to work once but then when i unplugged it again it got messed up again. is there a way i can buy a new box??
Yes you can buy a new box, but can you please explain the problem in more detail and post a picture of exactly what the problem is.
highperboi
you know how there iis 4 pins coming out of the circuit board for the connecter to the ecu. well the bottom right one broke off. so i de soldered it and then i replaced it with a pin from the connecter in the middle because im not using it. i think its for the clutch switch for 3 step? well i soldered that one back into the spot where the broken one came out of and i plugged it in without the case around it and it worked so i disconnected it and put it back in the blue box and then tried it again and it stopped working. i might of bured the circuit board some how maybe? i dont know ill take pics and post them up asap.
highperboi
i fixed it the problem was a bad connection from the pin to the circuit board i think the part of the circuit board was bured so i got a wire and by passed the bad section so now it works fine. but looks ugly.
