Looking for recalibration of specific tune thanks
Mr Plow
Post by Mr Plow »
This is the base tune provided by hondata.
k20a2-rsx-650cc12ohm-cyber-10psi
I need it retuned for lower compression. If this is possible let me know.
It's possible by taking it to a dyno and properly tuning it on the dyno. You have all the software needed to make the adjustments.
menfou
Post by menfou »
I used this .kal for my 9:1 Engine and +8? in boost column is the best for me with 93octane
Mr Plow
Post by Mr Plow »
Just want to make sure I understand correctly. If the ignition was say 41 degrees, yours is now 49?? Just trying to get a mental picture. Thanks!!
menfou
Post by menfou »
I don't modify before the column 10.
In the cybernation 10PSI.kal you have 13.5 for Igntion for 4PSI, and I put 21.5.
