2005 RSX KPro speedometer problem
We've improved the speedometer response for the 05 RSX / KPro. Our testing shows the cruise control now works smoothly.
<download version is now out of date>
Razathorn
Re: 2005 RSX KPro speedometer problem
Post by Razathorn »
Hondata wrote:We've improved the speedometer response for the 05 RSX / KPro. Our testing shows the cruise control now works smoothly.
Download here: KManager V1-2-1-0 Beta
I was about to go post this up on clubrsx -- but I see you beat me to it! Thanks for keeping us all in the loop.
rsx-s 05
Post by rsx-s 05 »
Thanks for the update
Now I got to go try it out
Performance* Hondata K-Pro W/ Wire Harness* Injen CAI* DCRH SS* Hondata IMG* Fujitsubo Power Getter Exhaust
rsx-s 05
Post by rsx-s 05 »
Works good + car feels better :D , But noticed
I'm not able to turn on OBD II
even if I check it then upload my kal
I notice it under Readiness Code it shows everything Not Supported
I know you may have done this for the Evap cell, maybe you could just do it for that only
it may not have anything to do with performance. but when it comes time for my emissions check they plug into obd port it will show not supported
then they may use a sniffer and I wont pass
could you please give back the option of turning on/off OBD II
I found out at least for me setting readiness to show all completed I did not get the cell @ 900+ miles, before it was from 400-500 miles
thanks
I dont want to go back to ver.07 :(
Edit: cool found the trick to be able to still use it went the time comes for
emissions check again next year, you turn off 05 speed sensor then click enable obdII then click speed sensor, save, upload :wink:
Thanks for the feedback. Comments on OBDII are noted.
rsx-s 05
Post by rsx-s 05 »
the new k Manager fix was working great until last night
I was crusing at 80mph and the speedometer needle just drop to about 72 and then went back to 80
this happened to me 3 times last night
