2006 RSX Type-S
pawlstevenz
2006 RSX Type-S
Post by pawlstevenz »
When will K-Pro be available for the 2006 RSX Type-S?
Will there be a version that doesn't need an adapter harness?
This has been covered in this thread http://www.hondata.net/forum/viewtopic.php?t=3764
pawlstevenz
Thanks for the reply. Sorry I didn't see that thread before. It answered my questions about the harness. I have more questions btw...
pawlstevenz
Well anyways, so I would need to send in my 2006 RSX ECU, then you would take a 2002-4 ECU and then put the code from the 2006 ECU into the 2002-4 ECU, plus I need the harness, O2 sensor, etc... I think I have that right correct me if I'm wrong.
So therefore, the 2006 ECU would remain untouched and in-tact when you send it back?
I have to supply the 02-04 ECU, Harness and O2 sensor? Where would I pick those up?
Then I can install K-Pro and a Turbo kit with all the goodies?
Are these lame questions?
<--- Noob
The 06 ecu is not needed by us. You might try ClubRSX or www.car-part.com
We also sell brand new ecu's for $600. You can purchase the sensor from any Acura dealer.
pawlstevenz
So theoretically lets say I want to put on a 700 hp Full Race Turbo Kit on my 2006 RSX Type-S. I know I would need to get K-Pro, but the problem is, that I don't think it's even been done. What would I need to do?
The 06 is the same as the 05.
http://www.hondata.com/dynok20-05rsx.html
