HELP!
REDDOG
HELP!
Post by REDDOG »
i have a 1994 honda civic cx HB w/ a B16A2 swap that i just recently bought, well the problem is the previous owner didnt put in a new ecu or hondata unit, he just hooked the VTEC up to a toggle switch :x, i know that cant really be good for it and sence i really dont know much myself about cars seeing this is the first car worth doing anyhitng to i have ever owned, i need to know what i should have put or or what i should have done. ANY help would be greatly appreaciated!
What ecu (code on side) is in the car?
REDDOG
Post by REDDOG »
dont know if this is what you are looking for but this is all i found
37820-p30-020
470-303848 AXE
hopefully thats what u are asking for! if not then let me know where to look
Is the ecu rectanguar or square?
With the current ecu you can use either the s100 or s200. If you convert to a US OBD1 ecu then you can also use the s300.
REDDOG
Post by REDDOG »
would it be better to convert so i could use s300 or wouldnt it really be a big difference, and if so how much and what would it take to convert?
You've never answered the questions so we know what ecu you really have. I highly recommend the s300, but you must be using an US version rectangular ECU.
