Daughter Board Communication Error
Posted: Tue Nov 01, 2005 10:37 am
by Ironraven
I did a quick search and didn't find an answer... Here's my setup:
- Kpro ECU
-Stock Greddy Turbo 440 16 ohm injector calibration
- 2002 Acura RSX-S
-Greddy Turbo kit w/ cat and 7 PSI spring and FMIC
-IBM R31 laptop
My CEL turned on, but when I went into Kpro to view the engine error code, all I get is the message "Daughter Board Communication Error". The car basically runs fine, although I'm having trouble datalogging because the Kmanager software keeps randomly showing the ignition as "off" and I have to unplug and replug the USB cable in. Here's what I've tried:
1. Yes I did move the ground wire to the engine block.
2. Changing USB cable.
3. Changing laptop.
4. Yes I did check for Kmanager updates...
I bought Kpro about 3 weeks ago, so everything is up to date; I'm lost. Anyone have any ideas?
-------IR
Posted: Tue Nov 01, 2005 10:40 am
by Ironraven
lol... I just saw the exact same thread halfway down the page... but there's no information in it that helps. So, I guess I'll just e-mail hondata and see what's up.
-------IR
Posted: Wed Nov 02, 2005 9:24 am
What spark plugs do you have? The Greddy kits comes with non resistor plugs.
Posted: Thu Nov 03, 2005 8:04 am
by Ironraven
I'm using NGK BKR8EIX resistor plugs, so I'm sure they aren't the problem. Thanks for the reply though.
-------IR
Posted: Thu Nov 03, 2005 12:04 pm
by AntonioRSX
Use a choker coil...(the little oval things on the USB cables that usually loops once or twice around it.) I installed a pretty big one, (about the size of an ice cube, looped the cable 3 times around it, and its worked great since.
a friend of mine recommended it to me and it stopped going off-line.
try it...
-T
Posted: Sat Nov 05, 2005 10:17 am
by Ironraven
AntonioRSX wrote:Use a choker coil...(the little oval things on the USB cables that usually loops once or twice around it.) I installed a pretty big one, (about the size of an ice cube, looped the cable 3 times around it, and its worked great since.
try it...
-T
My cables both had the static isolaters on them on both sides... I guess I'll have to send it back to Hondata.
-------IR
Posted: Tue Nov 15, 2005 6:09 pm
by bossman032
I had this problem. same exact problem daughter board error.
I can't data log. And car runs shitty what do you guys think is wrong..
