problems getting lc-1 to work with eld on s300
the_crazy_russian
Post by the_crazy_russian »
hi,
I'm trying to get my lc-1 wideband to work with my s300 on the eld port.I setup custom in the o2 settings with 0v= 7.35 a/f and 5v=22.39 a/f .I have selected eld in the o2 settings.
I have the brown wire analog2 (0-5v) from my lc-1 going to D10 on my p28. I've tried both eld disabled and enabled (my 99cx doesn't have eld) and I've tried both open and closed loop but I cannot get hondata to see the output from my o2. when dataloggingwith s300 a/f showes as 1. somthing , while eld is showing the proper voltages from the wideband. why isn't the s300 showing the proper a/f ratio but is showing proper voltages on eld port?
any help would be appriciated.
Thanks,
B
RMS
Post by RMS »
try
options
sensor setup
eld
change from
display min: 0 ->10
display max: 5 ->17
and see if that fixes you issue. let us know.
RaVer Motorsports (559) 733-4711
ravermotorsports@earthlink.net
the_crazy_russian
hi,
thanks for the suggestion, I gave it a go but no luck. I'm gona try and program the lc-1 to have the same output voltages as the lm-1 then just select it lm-1 from the drop down menu and see if that will work. if not I'll go through all my wiriring again :?
Thanks,
B
RMS
Post by RMS »
if the eld is showing the right voltages you have the wiring correct. somewhere you just have a setting wrong. it can be frustrating, but when you figure it out i bet it'll be something simple :)
good luck
Is the ELD still connected to the ELD? IT must be disconnected to work.
the_crazy_russian
my car doesn't have an eld. it's a 99cx. so I have the wideband connected to the eld pinout on the ecu.I haven't had anytime to play with this over the last month, but will have a little time over xmas to play around with it. I'm not givin up yet :D
Thanks guys,
B
