Eeprom Burner question
zerospeed
Post by zerospeed »
I was wondering if anyone has used another programmer besides the pocket programmer? The reason why i ask this is because I have been having problems with burning a chip with another programmer. I have a Enhanced willem programmer on the pcb3b board and I have had no luck with it on the hondata, but it seems to work fine with uberdata on my friends cars. So I just want to know if anyone else has had any experience with other burners besides the pocket programmer or if anyone knows why Im having problems..Thanks to everyone who reads this.
What software are ylou using to create the rom? version number?
zerospeed
Post by zerospeed »
Im using the Rom editor V3.6.4.0 version 3.0 and the program that burns the rom is willem eprom m51 version 0.97g
blownintegra
Post by blownintegra »
works fine.
zerospeed
Post by zerospeed »
Could you tell me if there are any settings that i need to change on the enhanced willem board? I did the dip settings and set the chip setting to at29 chips, but after i burn the rom on the chip and put it back on the car it starts acting funny. I would drive fine for like 10 mins and then the check engine light would flicker on and then off and the led on the box is still solid. It makes the car jerk when it comes on..
When the check engine light comes on, is the interface box flashing or solid? Are there error codes?
zerospeed
Post by zerospeed »
When the check engine light comes on its just for a split second, and as far for the box its still solid. There are no error codes, they dont show up at all
thanks
sounds more like a problems with your interface cable or a possible loose wire in the car.
zerospeed
Post by zerospeed »
The interface cable you are talking about is the one that connects the blue box to the ecu?
yes
