alpha-N ?
Super-Tuner
alpha-N ?
Post by Super-Tuner »
hello,
I was wondering if someone could explain to me what exactly the alpha n settins should be set do and how to set them up correctly? I understand that this will change map to tps ,but im confused where it says map value at closed throttle and map at wot?
CivicVTi
Post by CivicVTi »
I believe the map value at closed throttle indicates the column the car will look at with zero throttle (idle). I would set equal to the first column value. The full throttle should be equal to the last colum (1030mbar or so).
