How to adjust idle?
CivicVTi
How to adjust idle?
Post by CivicVTi »
Minimum idle works but only above 860 rpm for me. More specifically, if I set the idle at a value lower than 860rpm, it still idles at 860rpm. If I set it higher, the engine idles at the value I have it set (eg at 900rpm). Why I cannot get the engine idle below 860 rpm?
stock b18c-R Euro, 310RC injectors
JDMLyfeStyle
Post by JDMLyfeStyle »
i believe ITR are suppose to idle between 850-950 RPM's... thats what ive always noticed with them
What are your settings for the idle based on ECT?
CivicVTi
Post by CivicVTi »
I left them at default values which is 702rpm when the engine is warm. They do not seem to work either.
