Nitrous control output wiring and load question
ridewhencan
Post by ridewhencan »
First, I finally have my s300 and I really enjoy learning about and using it.
Question about Nitrous Control. I have a direct port wet system and p28 ecu. I understand that I should re-wire my activation (input) switch to B8 PSP. I am less clear on the output. I understand that I should take my relay #85 wire and attach it to either A20 or A15 but does that make the AC or PCS inoperable? I have to cut which ever wire I use, right.
Hey, I just realized the tech wiring diagram has A20 or A15 but the output control also has A17. I don?t have IABs so I should be golden but do I want to invert the output?
Any guidelines for setting the load parameters?
ridewhencan
A little help, please.
? restated - If I wire my activation (input) switch to B8 and the #85 wire from the relay to A17 do I have to invert the output in either case?
yes the wire you choose to use cannot be connected to it's original location. If you have a P28, the IAB output will not work, as that ecu is missing that internal circuitry.
ridewhencan
Thanks. I forgot that the p28 doesn't support the IABs. Looks like A20 or A15 for the output then.
