car wont start flashing Light tell me what you think
TBoDelSol
Post by TBoDelSol »
ok here is my car
93 Del Sol D16z6 fully built/ turbo, s200 hondata, Full Nology ignition system.
ok here is the problem:
ok so i drove out to meet someone got to t he spot and waited car was off but in ACC mode to listen to radio and blow heat left it on for 2 hours i cranked the car once after that the 2 hours to see if i have a good battery so it cranked and then i turned it off and back to acc mode again left on for 45 more minutes then tryed to start the car and it turned over dead. so we charge back up my battery and the car will turn over but wont give it fuel.
ok things i have done:
checked the fuel pump - it works
checked main relay - works
checked wires inside - they work
checked igntion - it is fine
what worries me i called my preformance shop to see what they thought told them about it they asked what about my hondata told them the light on the box was bleeking they said its supposed to stay on all the time.
i need hel;p to get this started this is my DD and would like to get it going again.
I know this is long but thanks for reading it and helping me out. - Brian
I would suggest burning the eeprom again and see if the interface box stops flashing. It is possible that improperly jumpstarting a car could send too much voltage into the ecu and cause a problem.
