Motec 3 Bar Settings in Kpro
jsimon9633
Post by jsimon9633 »
Ok I am having an issue with this
it seems that at idle it reads 2lbs of boost and hence its screwing up my whole thing
I am using the kpro default settings of 609 scalar and 2 offset for the motec 3 bar map
I have a vacuum manifold source im getting directly from the intake manifold
I have a vacuum connected to the botom port of wastegate and my type r greddy bov
i do not have the vacuum line connected to the port on the turbo yet, would this affect anything?
what settings have you guys used on the motec 3 bar to get it to work right on kpro? thanks!!
__________________
It seems like the MAP sensor is damaged - try another sensor. The MAP sensors are delicate - incorrect wiring or a short for even the briefest moment will damage the sensor.
Also make sure that the stock map sensor is no longer wired in.
jsimon9633
anyone have the wiring diagram that comes with motec?
I tried to search for it but no luck
I have 3 wires
green/black, red/black, and yellow/black
which wire goes to which letter on the 3 bar? A. B and C?
