370cc Injectors with 05 Reflash?
klutchrsx
Post by klutchrsx »
will increasing the Injectors flow rate from my stock 310cc to 370cc help with air fuel mixture, i am assuming that im running twards the lean side in my 05 with race header, Cold air, Nextgear intake manifold gasket and the reflash of course and stock exhaust. (not positive just an assumption that its lean, i will know for sure after the Dyno)
i ran a few searches, here and on clubrsx.com but found nothing that was helpful to me. i dont think anyone even has 370CC injectors
also can i switch to 370cc from 310cc on the reflash with out doing any other tuning? in other words can i leave everything the way it is and just plug in new 370cc injectors?
thanx
Nick :?:
2005 BOM Type S
13.870@ 102 MPH with just Cold air and Race Header
Shooting for 13.3-13.5 @ 104-106 with Reflash and nextgear intake manifold added, tires
Do not change the injectors wiht the Reflash. I you want to add larger injectors, then you need to get the K-Pro to properly tune everything.
