Euro Civic TypeR + ITBs
CivicVTi
Post by CivicVTi »
Hi. The modified TPS signal is gray on the corresponding K-Manager Tab. I guess the PRA does not work with ITBs. My only option is therefore using a PRC I have. Will this work?
you can use a PRB calibration on the PRC, but you will aslo have to change your wiring in the car for the primary wideband oxygen sensor to work. I would recommend contacting one of our UK dealers for assistance with this modification.
