KManager v1.2.1.2 Problem
640k
Post by 640k »
Version 12 isn't letting me change CAM angles in any calibration. I have tried both calibrations that I have saved/created and calibrations that come with the application and none of them allow me to change CAM angles.
If I downgrade to v11, I am able to change CAM angles, but I get a warning that a newer version of KManager was detected.
You'll need to be more specific. What exactly are you doing...please give step by step details. From what you have said, I cannot reproduce the problems.
640k
Post by 640k »
Spunkster wrote:You'll need to be more specific. What exactly are you doing...please give step by step details. From what you have said, I cannot reproduce the problems.
When I open any calibration and try to change any CAM angle in the CAM table (low or high) using CTRL-J, none of the values take. It doesn't matter if I select one, many or all or if I try to change using percentage, value or exact value. They won't change.
If I uninstall 12 and install 11, I can make the changes. 12 was installed on top of 11 (without uninstalling).
Please post the calibration you are using, because when i go to file new and open a calibration I am able to edit the cam angles perfectly.
Please provide very detailed step by step descriptions of how you load the files and what you click on.
640k
Post by 640k »
Spunkster wrote:Please post the calibration you are using, because when i go to file new and open a calibration I am able to edit the cam angles perfectly.
The install is working on my laptop but not on my PC. There must be other issues with the install on my PC. The steps I described above are the exact ones I took. I don't have another way to explain it. v12 works on my laptop.
Uninstall KManager and delete the Program Files/KManager directory (make sure that you save calibrations first).
Re-install the lastest version, and don't 'downgrade' versions.
Under Options>Settings>General check the 'Table change for increase and decrease keys'.
Failing that, post the calibration here.
