Immoblizer not matched "problem"
bluek20a
Post by bluek20a »
i just recently traded my stock ecu for a kpro ecu on the clubrsx forum. the guy Eric who i traded with,traded his from another member. but this member sold his car. which now i need his vin number or the immoblizer break code to keep my key light from flashing. well i contacted the guy originally got his ecu done through hondata. but he sold his car which he couldnt give me the vin number. is there a way hondata keeps records or have codes to break the immoblizer code? sorry if this is confusing im just tired of the stupid light flashing at me...
PLEASE HELP!!!
Razathorn
Post by Razathorn »
I have been working on this car as well -- Originally the problem was that the car was taken to the dealer without a laptop and any way to enable the immobilizer functionality in k-pro. I went on the last trip to the dealer and had them try after uploading a calibration with the immobilizer enabled. This allowed their honda computer to access the immobilizer, but they still weren't able to match it up. They seem to think they need the VIN from the original car that the ecu came with as bluek20a said.
Wayne
bluek20a
Post by bluek20a »
i will give hondata a call tommorrow
Razathorn
Post by Razathorn »
It may be worth noting that this ecu was a different revision than mine was. Perhaps the immobilizer needs a reflash? Perhaps I don't know what I'm talking about. :lol:
What vehicle & year? As long as the immobilizer is plugged in and enabled in the ECU the ECU should be able to be matched to the immobilizer.
Razathorn
Post by Razathorn »
Hondata wrote:What vehicle & year? As long as the immobilizer is plugged in and enabled in the ECU the ECU should be able to be matched to the immobilizer.
The car (and hence the imobilizer) is an 02 rsx type-s if I recall correctly. The ecu is from an unknown car, but it is a type-s 02-04 prb ecu. I have an 03 and compared the ecu part numbers and mine was a different revision of the ecu than his (like AX or something).
We went to the dealer, I enabled the immobilizer in kmanager, and they used the HDC with the odbII port to access the whole setup. Prior to having the immobilizer enabled, they couldn't even get into it. Once enabled, they could actually try to match them, but the HDC kept telling them there was a problem. The acura techs were convinced they needed the VIN from the original car the ecu came from in order to lookup a password / security code to re-program the units with the new ecu. Their HDC just seemed to always refuse them no matter what we did.
Wayne
bluek20a
Post by bluek20a »
i have a 02 rsx type s i need the original owner's vin number. im not sure if you guys keep that signature form.
The actual VIN shouldn't make any difference, as the pre-05 ECUs don't record the VIN. Just find any 02-04 RSX and use that VIN.
Make sure the techs are using the 'replace ECU' function from the HDS.
640k
Post by 640k »
Hondata wrote:Make sure the techs are using the 'replace ECU' function from the HDS.
That could be the actual issue. When I had mine matched, I told them it was an ECU swap and to just match the immobilizer to the ECU. It was relatively painless so maybe you just need to try a new dealership? :D
Razathorn
Post by Razathorn »
I will ask them to try the replace ecu function. I bet that's what it is -- I think they were just trying to match keys up.
bluek20a
Post by bluek20a »
HEY WAYNE WHEN DO YOU WANT TO GO UP TO THE DEALER AGAIN? FRIDAY OR SAT? LOL
Razathorn
Post by Razathorn »
bluek20a wrote:HEY WAYNE WHEN DO YOU WANT TO GO UP TO THE DEALER AGAIN? FRIDAY OR SAT? LOL
1.5 days after your get your caps lock key fixed.
Razathorn
Post by Razathorn »
Okay, so we went in and we got further. The only option on the HDS was 'replace ecu' under the imobilizer section from their main screen. The other option was replace ecu under pgmfi I think. It did the same thing. Once they entered the password for the ecu correctly, it came up and said NO DTC or DCT if i recall correction -- I asked the tech and he said it was what happens when the ecu cannot be talked to via the odbII port.
It is obvious that it is talking to the ecu however -- they can pull the information, access the imobilizer after we enable it.
At this point, we're somewhat lost for ideas.
bluek20a
Post by bluek20a »
acura has tried every option there was on the HDS system. could i get any other opinions?
bluek20a
Post by bluek20a »
i dont no how to disconnect the immo..but so much for hondatatatata help.....pointless for my threads........................
