3 bar map sensor ( or any sensor) not reading right by Kpro
jsimon9633
Post by jsimon9633 »
for some reason i cant get any 3 bar or even my stock map sensor to stay in the right columns in kpro
what could be the possible reasons for this?????
what kind of things can cause this???
could it be a bad ecu??? im drivnig myself crazy trying to figure it out and i have verified with voltage readins that the 3 bar is correct and have also tried my stock map sensor
Either bad wiring, or you have changes some of the settings, such as Alpha N. Post your calibration.
jsimon9633
Spunkster wrote:Either bad wiring, or you have changes some of the settings, such as Alpha N. Post your calibration.
i reset the ecu and maybe its working now
