Gear Compensation (fuel & Ignition Compensation)
Jordo
Post by Jordo »
If I adjust the Ignation Compensation for each gear, Is it going to adjust it for the entire map or only when its WOT?
Example:
1st gear = Retard timing by 3 degrees, (will it pull 3 degrees even at partial thorrtle)?
s300
The whole time in that gear.
Jordo
Post by Jordo »
So it would definitely be best to only use it on a race map. WOT only basically
s300
b20luda
Post by b20luda »
Is there gonna be an update so we can have these gear based changes based on throttle angle or load.... for example - so were not adding fuel in 5th gear while cruising but only at WOT or above a certin throttle angle
The current functionality is fine. Generally if you need to make a change by gear at full load, you'll need that same change at partial throttle. Second, with closed loop operation at partial throttle a small fuel change will not make any difference.
