High Cam axis ??
Djbower1
High Cam axis ??
Post by Djbower1 »
Hi just a quick question for all.
If you vtec is engauging @ 6000rpm what should the axis rpm start @ for you fuel and ignition table???
common sensce would say start @ 5500 to 9000... why would you start it @ 0 then 600rpm becuase your never going to be in vtec below at least 4000rpm.
Whats everyone think??
Hondata??? any advise???
Djbower1
Post by Djbower1 »
any1 :(
jdmspecdc5
Post by jdmspecdc5 »
each cam (low and high) has their seperate ignition and fuel maps. judging by the 600rpm you said i'm assuming you are just looking at the low cam tables.
Djbower1
Post by Djbower1 »
Sorry i meant on the high speed fuel and ignition map can i set the axis on the left to start @ 5250rpm upto say 10000rpm instead of startiing @ 500rpm to 8950rpm see screen shot.
The reason i ask is becuae my vtec is coming in @ 6000rpm so below that the high speed map wont be doing anything
Yes you can do that.
Djbower1
Post by Djbower1 »
would you recommend doing it this way??
