Car starts but idle in column 4 and 5 P75 (S300)
oscar93turbo
Post by oscar93turbo »
Need help: My car starts but in the dattalog in idle the car is in column 4 and 5.
I read it should be in column 1 and 2.
What could it be the problem?
The file is not there...
The reason for it idling in cols 4 and 5 is because of low vacuum. This could be becuase of a low compression engine, bad compression numbers, bad leakdown, or a vacuum leak.
oscar93turbo
Its 9.0:1 compression enough for making the car idle at column4 and 5?
No...Do you have Alpha-N enabled?
oscar93turbo
Spunkster i'm using a stock map sensor. My car is forced induction.
oscar93turbo
Spunkster my car compression was 180, 182, 185, 179. but still the vacuum is in 15
Djbower1
Post by Djbower1 »
Get a new map sensor. yours sounds f**ked
x2gold
Post by x2gold »
Djbower1 wrote:Get a new map sensor. yours sounds f**ked
sounds like boost leak/clamp etc, or vac hose to me. Could also be your map like mentioned above.
Learning about S300 of course.
TurboLS
Post by TurboLS »
check and clean your IACV and FITV (if applicable).
TurboLS from Team-Integra.net
(703)919-2786 (C)
TurboLS
Post by TurboLS »
I was just wondering if you resolved your issue with the vacuum problem. Let me know what your problem ended up being if you have figured it out.
(703)919-2786 (C)
