Nitrous Setup For s200
Versatilx1
Post by Versatilx1 »
I have a s200 but im farely new to it. My goal is to use as a nitrous application and i want to know if anyone has some good tips that i can use. Like for instance i have a obd1 gs-r and if someone can give me some advice its dearly apperciated.
word
CivicVTi
Post by CivicVTi »
Do you still have the GSR intake manifold? If not, it better to use the IAB output to activate nitrous (considering you have a P72 ECU). Otherwise you'll have to use either the AC clutch (if you do not have an AC) or the purge control output. There is a nitrous wiring diagram in the tech section (main Hondata site). Good luck
Versatilx1
Nah i dont have the gsr intake manifold im using a skunk2 intake manifold. Also i have a p73 ECU is it worth trying to use this ecu? and what rom or so forth would you use setup wise?
word
CivicVTi
Post by CivicVTi »
Versatilx1 wrote:Nah i dont have the gsr intake manifold im using a skunk2 intake manifold. Also i have a p73 ECU is it worth trying to use this ecu? and what rom or so forth would you use setup wise?
I might be wrong but I think the P73 is OBDII and thus not hondata compatible.
