Full Throttle Shift Question
Djbower1
Post by Djbower1 »
:?: I want to set full throttle shift @ 6200rpm and have rev limiter @ 9500rpm.
My question is.. if i put the clutch switch on D6 does that mean when I put the clutch down ill have a temp rev limiter of 6200rpm? and when i release the limiter will go back to 9500rpm??
Hondata I need your knowledge
Dan
Yes this is correct.
Djbower1
Post by Djbower1 »
Do I just switch D6 to ground?
