idle
jdmspecdc5
idle
Post by jdmspecdc5 »
i've been playing with the car and s300 for awhile and have gotten most of my problems solved except for the idle. idle is pretty smooth but it stays at around 1k rpms. i've noticed that when the idle does stay to what I set it at 850rpm the car wants to stall and vacuum is around 19-18in. i've played with timing and fuel but cannot seem to nail the idle down. the motor is mechanically sound. just did a valve adjustment, changed oil, compression test, and checked timing. any suggestions on how to lower the idle to 850rpm?
With the IACV disconnected, what does the car idle at?
