p72 ECU prelude JDM h22a
JDuronM
Post by JDuronM »
I was told by my tuner that I could only use the USDM version of the p72 ECU is this true or can I use the JDM version. I have a MT '95 OBD I car.
I will be running the s200. Is the JDM ECU a p72j?
Thanks for any help.
Bobby
RMS
Post by RMS »
jdm will work with the s200, but it must be a manual ecu. 72J is auto and junk... not convertable.
RaVer Motorsports (559) 733-4711
ravermotorsports@earthlink.net
JDuronM
Post by JDuronM »
would USDM work better or is it exactly the same? Anything I should look out for?
the US version has a few more sensors, but they should operate the engine the same once tuned.
JDuronM
Post by JDuronM »
Is there any advantage/disadvantage of going with one or the other. Knowing what you know, which would you go for? Which ones are more plentiful out there thus cheaper? Also, I am in Georgia, is there anyone you would particularly recommend to do tuning?
Thanks again,
Bobby
Personally I would get the USDM ecu and the s300.
JDuronM
Post by JDuronM »
USDM it is. I do wonder why you would suggest the 300. I am N/A with a daily driver with no plans to go turbo, but would like to get as much out of my h22a as possible. I realize you are with Hondata and know all that system offers, but I have been told by your dealers that the 200 would be more than enough for my purpose. What more can I do with the 300 that would serve me that the 200 could not accomplish. Please give me as much info as you can! I want to make sure I buy right the first time.
Bobby
You can tune yourself gor about half the price. And you don't need serial ports or usb adapters. Less headaches.
JDuronM
Post by JDuronM »
I am not a tuner with a dyno, so I may really screw something up. Besides, after a good tuner who does it daily does his thing, how could I possibly improve on that as unfortunately, I have never changed oil before :shock:
For me self tuning probably would not be a good idea, although I am sure there is value in that for those who have the knowledge to self tune.
With that in mind, is there anything else that you could share in detail that would justify twice the price for me and my application specifically?
Thanks again,
Bobby
RMS
Post by RMS »
the s300 datalogging provides great feedback and is far superior to that in the s200. i can't overstate the usefulness of great datalogging.
the s300 also has additional tuning tables that enable more control for the tuner.
but if you are truly a hands-off owner then the s200 or even the s100 may be right for you.
JDuronM
Post by JDuronM »
No! Don't get me wrong, I don't have the experience now, but would like to learn. I fact I would like to have enough knowledge to take care of most anything that goes wrong or at least know what it is so that a shop can't screw me. Does'nt the 200 have data logging?
S200features:
Speed limiter removed (if applicable).
Tunable fuel and ignition tables.
Expanded fuel & ignition tables for boost.
Expanded rpm fuel & ignition tables.
A/C cutout.
Shift light.
VTEC control.
Adjustable rev limiter.
Launch control.
Full throttle shift.
Nitrous Control
Datalogging with HondaLogger software.
Datalogging with Palmlog software
ROM Editor tuning software.
I'm not trying to convince to consign on the s200, just trying to justify double the cost. I am new at this so I don't know enough to know the value. That's why I am asking.
Thanks everyone for the information. keep it coming.
Bobby
