S300 answers?
clockstick
S300 answers?
Post by clockstick »
Hello, I have a 1999 Honda Civic Hatch DX
I am wondering if the hondata s300 still allows for full normal operation of the stock ecu. and I simply tune the stock maps that are already in the stock ECU... or if I end up tuning in ranges outside the stock ecu like boost.
Also does it support dirrectly a Wide Band oxygen sensor, or do I need a controller unit for it.
will the unit support many different types of injectors? High/low impedance?
I want to keep my stock like operation but simply add a tunable boost range to my car?
Any information you can give me would be great.
A little back ground I am not a newb. I have a tuned 375RWHP mazda RX-7 Turbo running a Haltech I installed and tuned myself. I did all the work myself. Now I just want my daily driver to have some passing power on the high-way. Not looking to blow away all cars I already have a car to do that. I just want some more power on the highway and a litle more fun in the streets.
I would highly recommend reading http://www.hondata.com/aboutus.html
You will have to convert to one of the compatible OBD1 ecus form the list at http://www.hondata.com/ecus.html, then you can use the s100 , s200 or s300. You should download the s300 software (Smanager) to see how everything works.
Any wideband you use will still need a controller. We recommend the PLX Devices wideband.
clockstick
I read those both already, but the brochure does not include the s300 from what i could read it involved the s200.
I did answer a few questions I had
do those base maps come included with the s300 or only with the s200 and rom editor?
Thanks again.
Yes there are base maps built in to the software. Download the software and take a look. The s300 is the same as the s200, only it is cheaper and includes all options , is real-time programmable and fits in side the ecu.
There is a complete comparison of the systems at http://www.hondata.com/sproducts.html
