Basemap D15Z /edm/ ?
rtibor
Post by rtibor »
Hello!
I just received the S300, could someone help me to get the Civic D15Z6 /EDM/ engine's original basemap?
It is actually OBD2B, but the new control is OBD1 /P28-ECU EDM 5 speed manual + Hondata s300/. Could someone help me how to run / operate it? I have only found D15B in the program.
Thanks!
You cannot put an OBD2 program into an OBD1 ecu. You will have to start with the p28 calibration and tune form there.
rtibor
Post by rtibor »
Thanks, i will try it.
rtibor
Post by rtibor »
Could someone help me find an ignition and fuel-air chart with factory settings for my engine?
rtibor
Post by rtibor »
Would you please let me know which ROM should i start using with my s300 if I only have a lambda /sensor/ or o2 with 1 wire ? /not 4 wire/
because my ECU said error code 41 Primary oxygen sensor heater.
thanks
a 1 wire o2 sensor will not work with an OBD1 ecu. You will have to purchase a wideband if you want to get wideband readings (such as the PLX). To run properly in closed loop with a stock sensor you must be using an OBD1 4 wire O2 sensor.
