Help need to set tps
oscar93turbo
Post by oscar93turbo »
Need help, on how to set the tps in 0 at closed throttel.
You will have to loosen the screws that hold the tps and rotate it until datalogging shows 0 while the engine is running. from the factory the TPS has tamper resistant screws. You may need to slot these with a file or dremmel and then back them out..when you replace htem, use alen headed screws or a philips screw.
