02-04 ECU K-Pro to 05 ECU
KSMatic
Post by KSMatic »
So i have a 02 ECU that is K-Pro, what is the necassary steps to take to get it to work with 05?
I believe i would need the wire harness? Would i also need to send this back to Hondata to get the ECU adjusted?
Of course i will have the o2 Primary Sensor from 02-04 ready to go, anything else?
I tried to read about it but hondata page has not been updated since they at one part it stated, "Reflashes are still not available" http://www.hondata.com/dynok20-05rsx.html
I want to see if i can save as much as time and money as possible since i want to equipt the 05 RSX-S with a JRSC. I rather not go with Comptech but whatever works best.
If the ECU has already been prepared for K-Pro and has a K-Pro inside it, then it is a $200 charge to hav ethe ecu further modified for the 05 and the adapter harness. This does not include shipping.
KSMatic
Post by KSMatic »
Spunkster wrote:If the ECU has already been prepared for K-Pro and has a K-Pro inside it, then it is a $200 charge to hav ethe ecu further modified for the 05 and the adapter harness. This does not include shipping.
thanks for the speedy response, should i take this to hondata directly or any authorized hondata agency?
I am near by hondata.
If you are local and want a quick turn around try Epic Motoring (now in Wilmington next to Church Automotive).
