"Invert Purge Valve" 1.1.2 Feature - Reset when op
indynt
Post by indynt »
I've been using SManager 1.1.2 and noticed that every time I open a calibration file where I had previously selected "Invert purge valve" in the "Misc" tab (new 1.1.2 feature), it gets reset to un-checked. I'm not sure if anyone else noticed this, but I just wanted to report the bug. I don't think I need to post any files because it has happened with every calibration file I try.
Thanks...we will fix this.
tboostdsi
Post by tboostdsi »
same thing, when i go to create boost tables, and check the "retard ignition and add fuel under boost" they uncheck themselves when i go back under create boost tables.
The setting in the 'create boost tables' window are not saved from session to session.[/quote]
