need base map for turbo gsr
hotpocket
Post by hotpocket »
I have a turbo gsr with a greddy 18g kit on it.I have dsm 450cc injectors with a inline pro headgasket stock bottom end.I need a base map to get the car started.Thanks
Go to FILE, NEW and then you can create your own basemap.
tboostdsi
Post by tboostdsi »
HA SPUNK, hopefully you can add to my question. i have a b18c5 84 mm bore with your hondata p28 obd2b ecu. if i would like to create my own and new basemap, which file should i use. the p28 file, the p72 file (since it is for a b18). in other words, should i choose the name of the file or the description that best fits my engine? because the p28 file and b18 file are different. hopefully you can understand my question. thanks spunk!
Dee
Post by Dee »
P72 is for the dual runner GSR manifold. Use a P30 or P28 based file.
