Installing 05 Kpro Help!!
gabo
Post by gabo »
Sorry is this ?'s have all been answered. I searched and found no response.
Do I need to unplug my battery before I remove the stock computer and install the Kpro ECU?
Must the grounding point on the intake manifold be switch to the head?
Do i have to set some percentage of correction on the 'counter shaft driven speed sensor'??
Thanks for any help provided it is much appreciated.
You do not need to unplug the battery, you do need to relocate the ground, and if you load the 05 calibration then you should not need to do anything to the speedo settings.
gabo
Thanks a lot!!
Post by gabo »
Great customer service and quick answer. Thank you so much!!!!
