IAT Correction above 100 degrees F
daveG
Post by daveG »
I'm looking in the S-manage software and the highest IAT temp it appears as if it will correct for are 100 degrees Farenheit. Is it possible to edit anything in the S300 to change for higher IAT values, or is this as high as the stock sensor reads?
Also one other question, when you're on the dyno, can you adjust fuel/timing values quickly while loading the car?
You can change the table index for the air temperature correction, so the highest temperature is around 300 F.
Yes, you can alter values while the car is loaded on the dyno.
daveG
Post by daveG »
Is there a way to display the IAT value in voltage instead of a temperature value?
