what do i need to get?
ricky05
Post by ricky05 »
okay, i just bought a 2000 b18c longblock without ecu and tranny. im trying to find out which ecu to buy and which hondata to buy..or if i should even go hondata or greddy emanage. i am building it for turbo but probably only 10-13lbs of boost. what should i get? im gonna have a greddy boost controller to control boost...just thought i would get some suggestions from pros.
thanks
Ricky
You will need to use one of the OBD1 ecu's from the list at http://www.hondata.com/ecus.html, then you can use the s100, s200 or s300. I personally would suggest the s300 as all options are included and is realtime programable for a reasonable price.
