wideband sensor bosch
contectr
Post by contectr »
Hi..
i have a euro civic type r with kpro!
can i connect the bosch wideband sensor code 0 258 006 066 for datalog the voltage a/f ratio?
Honda Ep3 stock k20a2 jrsc
No you cannot. The PRA ecu can only us a narrowband sensor. To be able to use a wideband you must use the PRB US ecu and the stock wideband sensor from a US RSX (02-04).
contectr
Post by contectr »
but in the new version of the kmanager is not possible with aem uego?
CivicVTi
Post by CivicVTi »
You can actually use a wideband to datalog BUT you have to use its controller (eg the AEM or PLX or Innovate unit etc). In order to feed wideband signal directly to the ECU, you have to use the PRB ECU and stock US wideband.
contectr
Post by contectr »
ok...
where i can buy this kit for italy?
CivicVTi wrote:You can actually use a wideband to datalog BUT you have to use its controller (eg the AEM or PLX or Innovate unit etc). In order to feed wideband signal directly to the ECU, you have to use the PRB ECU and stock US wideband.
This is incorrect. This can only be done with teh SManager software. This will not work with the K-Pro as it uses a different type of wideband. IT does not measure voltage, but current instead.
