problem loading basemap.
tboostdsi
Post by tboostdsi »
floating point division by zero is the prompt i am getting when loading a basebin file. after everything is loaded there is no fuel and ignition tables. can someone help me or tell me why this is happening.
Can you post or email the bin to us?
Also please post exactly what steps you are taking to load this calibration. DOes the same thing havppen if you go to File, New and use one of the base calibrations built into the software?
tboostdsi
files
Post by tboostdsi »
file, open, click file name"b18supercharger440" then a prompt appears and says "floating point division by zero" then i click ok. then it goes to the next prompt "CONVERT V3 ROM" change to 440 injectors then click ok and all the fuel maps and ignition maps in the tables are at zero. here is the file......thanks for the info.
The problem is that a proper bin file will be 32KB in size, and the file you have is a 17KB file...it is corrupted.
