+++ Help+++ brake line on ecu??
you know i got sol!
Post by you know i got sol! »
i have hondata s200.. and it seems that i am not able to set up anything.. (with the button)..(it blinks but when i go to set it with the brake it doesnt detect it)..so rev limiter, launch control, shift light.. etc..are not working.. i read up and have searched.. and i have concluded that the brake line on the ecu might be disconnected or faulty.. the question is which/where is the connector on the ecu has the brake line, so i can replace it.. please if someone can provide a pic.. it would be awesome.. oh yeah i have a 98 obd 2 gsr.. running on obd 1 p28..
On the OBDI connector the brake switch is D2. You can check that this pin goes to 12V when the brake pedal is pressed.
you know i got sol!
thanks for your help hondata.. i was curious has anyone installed a swtich (for the brake line) to work it manually? is this a bad idea? has it been done before? sorry for all the noob questions..
Are you using an adapter harness or an OBDI ECU with built in OBDII connectors?
you know i got sol!
i am using an obd 1 integra ls harness (all neccessary vtec items wired)..on a obd 1 p28 on a obd 2 gsr motor..
check continuity form the switch to the ecu
you know i got sol!
how do i go about doing that?
