s300 into my crx delsol
redsol
Post by redsol »
hi guys,
Going turbo on my b16a2 delsol and i want to run the s300. on the wizard on the main page there are notes below the 93-95 delsol
Notes
Manual transmission only.
The stock ECU cannot be used, and must be replaced with another OBDI ECU.
can i use my stock ecu? its a uk (which are the same as the u.s casings etc) and the model number is P30-G00. whcih is the same ecu used in the eg2 civic vti here.
will this work with the s300?
cheers
Yes it will work, and the application wizard has been corrected.
