B18C5 with Revhard Turbo SC61 440 injectors
Calibration for B18C5 with Revhard Turbo SC61 440 injectors
HondAcura
A Post to Thanks
Post by HondAcura »
Wild CRX
Post by Wild CRX »
Thanks dod
From Mild To Wild
burmese434
Post by burmese434 »
has anyone tried this and had good luck with it?..If some one can change from 440 to 1000cc that would be great
jamesfawcett
Re: B18C5 with Revhard Turbo SC61 440 injectors
Post by jamesfawcett »
hi spunkster, im having trouble setting up my fuel on my map at part throttle im getting really bad mpg,
i have the same injectors as you here, im going to copy your fuel values to my map and try starting from there so thanks for this, do you get good mpg?
boostedmonkey
Post by boostedmonkey »
whats up with the timing at 15lbs .. 40 degrees ?
ef8904
Post by ef8904 »
what kind of changes for 9:1 rc550s 83mm
forevertrj
Post by forevertrj »
boostedmonkey wrote:whats up with the timing at 15lbs .. 40 degrees ?
looks like it was only tuned for 11.9 psi of boost and you'll need to do the rest if you want more boost, also look at the fuel tables, anything above 11.9 psi for fuel is a value of 0.
Do1313R
Post by Do1313R »
Has anyone ran this calibration lately?
Ivanz92
Post by Ivanz92 »
i've been using this tune for about a year now, on stock jdm b18c with a ebay gt35 on dsm 450cc injectors, on 10lbs of boost. small amount of tweaking, including disabling a couple things.
Contella
Post by Contella »
I just plugged this in with my injector, MAP parameters..and disabled knock, ELD, etc. on my LSvtec fresh rebuild, first S300.
Working alot better than the one I was trying to make starting with stock ITR.
Idles well...nudged into boost and AFR's are 10's or so 👍
New clutch too, alignment totally screwed cuz new rack, so I cant run it very hard rn.
Thank You!
ilyyoungrock
Post by ilyyoungrock »
hopefully this helps
SkateOrCry
Post by SkateOrCry »
solid starting point for anyone running B18C5 with SC61 440s
five nights at freddy’s 2
