B18Csupercharger 12 ohm 440 injectors
picnic_george
Post by picnic_george »
Is this the same map you use on the Jackson Racing s300?
Yes
Zoomie
Post by Zoomie »
What octane was used when tuning this calibration?
grado
Post by grado »
what is the difference between this calibration and the other one titled
"B18Csupercharger 440 injectors"
one uses 12 ohm injectors, and the other uses 16 ohm injectors.
tboostdsi
Post by tboostdsi »
will this work for a b18c5 9.4.1 w 9lbs jrsc?
grado
Post by grado »
Is there anything that needs to be altered in Smanager once the calibration has been uploaded successfully? Would it be safe to drive approximately 25 miles to my tuner?
