Help with code
josh green
Help with code
Post by josh green »
My car is displaying this through kpo.
Error code 39-1
DTC P0600
The description was lost due to a dead battery. My setup is a 95 cvici cx, Hybrid-Racing harness. I beleive thats all the electrical stuff that I have that isnt stock and was needed for the swap. When the car is idling, it seems to skip and studder and some times it just stops runnning and then starts back up as though it was cut off for the slightest secone and then cut back on. If anyone could tell me what it is I would greatly appreciate it.
chunky
Post by chunky »
Josh, this was the code description you told me via phone yesterday.
39-1 p0600 serial comm link malfunction.
also, josh has a k20a2 swap in an eg chassis. Everything on the car was working properly for quite some time and the swap is basically stock - it just has i/h/e.
You can take me out of the race, but you can't take the race out of me.
That error is because it is an engine swap. You must disable the multiplexor under MISC. This has nothing to do with how the car is running.
Garrett_si
Post by Garrett_si »
this week on our K20 the code on the K-pro was active
but no CEL in cluster
actually the CEL is ON and the K-pro show us the VBU code
someone know why?
Garrett_si wrote:this week on our K20 the code on the K-pro was active
someone know why?
You lost me there. You must give better details. Post datalogs and calibrations.
Garrett_si
Ok last week the K_pro give me a code : VBU High Voltage
but no CEL
this week their is a CEL and K-Pro give me the same VBU High VOltage
I found that the VBU wire on ECU need 12V when ignition is OFF and 0V when ignition is ON
I justed cut the wire on E7 on the ECM
Stop. You are close to making the classic engine swap wiring mistake. Do not feed VBU / E7 voltage of any kind, otherwise the main relay transistor will burn out.
The ECU uses E7 to ground the main relay, and also gets a current trickle via the main relay coil side, which is the VBU. You must not put voltage down E7 - the only correct wiring solution is to use a main relay. See http://www.hondata.com/techk20wiring.html
Garrett_si
E7 is now cut, so I dont have 12V there, no posibility to burn the transistor
