tables follow vtec huh.......
civicbynature
Post by civicbynature »
Can somone please explain to me what the two options under the options menu (tables follow vtec) and (realtime update) do. I have searched the help menu and can't find what these two options relate to. do I need them on or off or what. any info would be greatly appreciated. :?:
jdmspecdc5
Post by jdmspecdc5 »
real-time update means you can make changes to your calibration while the car is running and the laptop is connected.
follow VTEC means that while datalogging if you go into VTEC then the datalog will also follow and switch to the hi speed table.
civicbynature
ok so my second question is if the realtime update is checked on and the engine is running. can i change settings and they change automaticlly or do i still need to upload after everychange to update the computer.
Changes to the fuel and ignition tables are automatic, and changes to parameters are updated as soon as you move to another field.
