Info about K24 "race" basemap?
NickZED
Post by NickZED »
Hey, I just wanted to know some specs about this K24 basemap with 650cc injectors, ITR cams, race header etc. etc.
I wanted to know if this would be good for my setup, which doesnt have head porting or anything... it has 12.5compresion, ITR cams, DC sport TSX header (no cat), and 2.25 inch exhaust on PRB intake manifold...
Would this be the best place to start tuning from? Will be be running rich with this map? Where should I focus on changing parameters first based upon the differences between the setup which the map was made on and my setup?
thanks for the help!
The basemap will probably work for you, but remember that a basemap is just to get the engine running, check for problems, and then drive to the dyno.
